Big IP cookie not getting invalidated in PRPC 7.2.2 when Passivating to database.
When configuring database passivation in PRPC 7.2.2 I am seeing that the user data gets passivated to the database but the BIG IP COOKIE is not getting invalidated by PRPC. Below is the configuration placed in the prconfig.xml file.
<env name="session/ha/Enabled" value="true"/>
<env name="initialization/persistrequestor/storage" value="database" />
<env name="session/ha/quiesce/strategy" value="slowDrain" />
<env name="session/ha/quiesce/customSessionInvalidationMethod" value="configurable-cookie-invalidator"/>
<env name="session/ha/quiesce/cookieToInvalidate" value="BIGipServergdmuat-443"/>
If anyone has had this issue before and have a solution please advise.
Issue resolved: With previous version of PRPC before you passivate users across nodes we would follow the below steps.
New Steps:
With the 7.2.2 and later PEGA has move to immediate drain instead of slow drain and has changed the process a bit differently.
PEGA should be working on updating their documentation to reflect this new process. Also please find reference from F5 on the matter.
https://support.f5.com/csp/article/K13310
