Defects in Pega 7.2.2? have they been fixed?
Bad form to mix topics I know, but I am running into two separate issues in designer studio and I am wondering if they are found, fixed, etc.
First: In the tracer, I can't set breakpoints. This is a real problem because I can't break to look in and see what is happening. Has this been reported/discovered/fixed? Is there a hotfix available?
Second: With the migration away from forms, there is a side effect when developing rules where if something is incorrect, for example, a page name is missing a "." or there is a typo, the rule will not open. The entire developer studio hangs for 5+ minutes until an error is finally displayed. The problem is, there is no way to open this rule and fix the issue. Has this been reported/discovered/fixed? Is there a hotfix available? If not, what are the plans as this is a real problem when developing.
scott
