TCS
Last activity: 16 Nov 2017 6:54 EST
How to convert property holding xml to xml file and send it to a location
In our requirement , we were supposed to build an xml file and send it to some external location. I have prepared the xml and hold that xml in a property but now I have a concern, how to convert that property value(holding xml) into an xml file and transfer to an external location.
Thanks in advance!!
TCS
Hi Ujjwal,
That issue is fixed now .
In the screenshots that you have shared , I am holding an xml in "Primary.TestTest" where primary.TestTest is of type text. Now when the connect-File is called I am getting an error as below.
Step Status: Fail
Step Status Info :** Couldn't map String parameter from HTML Stream: Missing stream source page:
Can you please tell me how can I fix this.
Thanks in advance.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689967000/4857ba23-514e-4145-8ab6-6c3b63127c6f.png?itok=lwb5f6-e)
Hi Sarat,
You can use connect-file method in an activity to do it.
TCS
Thank you will try and get back to you..
TCS
Hi Ujjwal,
I gave the destination path as C:\xyz . there is a folder created with the same name. But when I am clicking on test connectivity it is showing that destination not found. Can you suggest me wt to do .
Thanks in advance..
Hi Sarat,
Can you send me the screenshot of what you have tried till now.
Can you also send screen of the error that you get.
Ujjwal
TCS
here in second pic it is shown that the destination path fail
TCS
Hi Ujjwal,
Step Status: Fail
Thanks in advance.
Hi Sarat,
I have used map from ClipBoardProperty and used Text property that as XML as string.
Can you send screen of your activity please for me to understand more on that.
Ujjwal
TCS
Hi Ujjwal,
I was able to fix it now ujjwal. Thank you so much for your support.
sarat
