where to located prlogging.xml file in pega
Hi, can anyone help in locating prlogging.xml file in pega.
i dont have access to websphere server on which it is installed.
thanks
thanks
You don't need access to websphere. if you have access to the box / node with WINSCP or putty, you should be able to access the file. Your Admins, or who ever installed PRPC should know the file location. IT may be under the /web/appuser directory.
Hope this helps
Depends on our application server...
REFERENCE
