Normal user privileges after deployment
I'm planning to install Pega 7.2.2, running on Tomcat and Oracle DB (single-schema).
After deployment, I wonder how I should set normal users' privileges.
I think these users can use application if they have select/insert/update/delete privileges,
but the install manual of Pega 7.2.2 says I should grant some CREATE permissions to table, procedure, view, type and trigger.
Is this necessary set for normal user, using pega application for creating works or checking reports?
I want to confirm if I misunderstand or not, although this post (https://pdn.pega.com/community/product-support/question/user-privileges-run-pega-split-schema) might be related.
