Last activity: 20 Oct 2018 4:39 EDT
Access Dynamic System Setting value specific to Node Classification
I have a reasons to access the value for agent/threadpoolsize in Rules. We are configuring this (in 7.1.9) in DSS, and we are also using node classification to vary the value by node type i.e. <env name="initialization/nodeclassification" value="background" /> in prconfig.xml.
For more information on this configuration see https://docs.pega.com/how-compose-key-prconfig-dynamic-system-setting
I have been unable to access the correct value for the current node. The Engine API PRSystemSettings.getDynamic() only returns a value if the fully-qualified key is passed e.g.
@Utilities.getDataSystemSetting("Pega-Engine","prconfig/agent/threadpoolsize/background")
Is there any way to access the value of the prconfig setting initialization/nodeclassification (specific to the current node) so that I can build the DSS key dynamically?
Thanks.
Unfortunately the conclusion of this conversation was that it is not possible.
It sounds like when you run @Utilities.getDataSystemSetting("Pega-Engine","prconfig/agent/threadpoolsize/background") on a background node it returns a value, but it does not if that is run on other node classifications. Is that correct?
If so, this isn't exactly what you're looking for but if nothing else you could run getDataSystemSetting() for background, see if it returns a value, and if not, check for a different node classification until you determine what the node is.
Hi Nick. Thanks for the suggestion.
Unfortunately the API method just returns the value of the match on the key irrespective of which node it is, so I cannot test the result to determine which request to issue or use the result to infer the node.
I am still looking for ways to determine the classification name for the current node. I now have a simple function that will return a DDS specific to the node, but only if the classification name is passed as a parameter!
Specializing the prconfig values via nodeclassification is applicable to only those DASS which are configured as prconfig. While startup the prconfig corresponding to the appropriate node classification are read and available wherever they are referenced. The same is not applicable for DASS. And we do not have a public API that lets you read the prconfig settings.
Thank you for your reply. I can see the values varying by node in SMA. Might it be possible to use JMX to read the setting that is returned to the SMA?
What exactly you mean by when you say the values are varying by node in SMA. Are you talking about the prconfig values that you are seeing?
Yes. One node has one value and another (with the category declared) has another.
ObjectWise Consulting Group
Hi Healj,
I have the same requirement as you. Did you solve this problem?
Thanks.
CIBC
We are facing a similar issue. We have multiple WebLogic nodes on separate physical servers. On each server we have server specific settings such as MQ queue manager name. At run-time, a node needs to know to what MQ queue manager to send/receive messages. Using DSS doesn't seem to help.
CIBC
Sure, I created a new post here:
https://collaborate.pega.com/question/how-define-server-specific-settings
Thanks!
CollabPartnerz
Could you please try with below link
CollabPartnerz
Please find the below link might help you
https://collaborate.pega.com/question/will-backgroundprocessing-node-classification-stop-user-access
