Not receiving the messages published in Kafka Apache topic
We are trying to create an application that listens to a Kafka Apache server topic. The Pega Platform and the Kafka Apache are not in the same server. We had followed the configuration suggested in the 3 tutorials over the subject released in pega 7.3.
We are publishing messages in the Kafka topic, we had also configured a consumer to verify the messages are flowing to the topic. The issue appears because the messages are properly received in the consumer, but it is not received by the subscriber present in the application. Has somebody else faced this issue? I would appreciate any suggestions to solve the problem.
Best regards,
Jordi
Hi Jordi,
Could you tell me a little bit more about your application? You are using the Pega Kafka Dataset to post messages to a Kafka topic? Is this via a Decisioning data flow or are you using an activity to post to Kafka (i.e. via DataSet-Execute)?
What about on the receiving end? Is this a Decisioning data flow or something else? If yes, is the "read from beginning" set or not set on the Kafka dataset? If it is a Decisioning data flow, are you starting the data flow then posting to a Kafka topic...or are you posting to a Kafka topic then starting the data flow?
thanks,
Gareth
