SQLQuery Component - Keyword not supported: 'application intent'.
Hi all,
I'm working on a solution to query data from an SQL database and use the data to perform other operations.
When I configure and test the connection, the connection is successful, but I'm getting some errors when trying to save the data link:
Using these settings:
Hi all,
I have also tried different SQL providers and added "ApplicationIntent=ReadOnly" to the Extended Properties with no luck.
I can successfully test and save the configuration for other DBs, but this one needs to be "ReadOnly" in the ApplicationIntent property, so I can't use the Data link defaults.
Has anyone seen any similar problems using the SQLQuery Component?
Thanks and regards,
Ben
