Sberbank
RU
Last activity: 21 Sep 2017 6:44 EDT
AES for PRPC 6.х
Good afternoon.
Please help find the manual for installation and configuration and reference to the distribution of AES for PRPC 6.x.
Thank you
Sberbank
RU
Very strange. Here in this thread (https://pdn.pega.com/community/pega-product-support/question/autonomic-event-services-aes-35-installation-62-sp2) AES is discussed in 3.5 PRPC 6.2 SP2. It turns out that there are 6 PEGA AES?
Mauricio Castillo Perumalla Ganesh
Updated: 19 Sep 2017 5:58 EDT
<Edit Note> It does look like there is a support for AES on PRPC 6 platform, I did find several articles over this. I'm still not sure if there is an installation guide though. Let me try to find that out!
Hello!
I wasn't able to find the AES installation Guide. Have you already received the media (installation files)? I'm wondering if they would provide a ReadMe file along with it which has the installation instructions.
AES 3.4 and 3.5 (which run on 6.x) look to have been sunset, so you can no longer request the media. If you plan on setting up a new AES instance, you should do so using a newer version of AES and Pega.
Sberbank
RU
Understood. Thank you. going to do an upgrade to PEGA 7
AES 72 is the most current version of AES available. AES 72 runs on Pega72 and provides governance, monitoring and management features for Pega 5, Pega 6 and Pega 7 systems. There are alerts introduced post Pega 72 that are logged by AES 72 but do not create cases.
AES 73 will soon be available. AES 73 runs on Pega 73 and fully supports Pega Platform 5.4sp2 through 7.3.
Sberbank
RU
Thank you all. Will start to prepare the server for AES 7.2
Sberbank
RU
please tell me what are the system requirements for AES 7.2. What is the necessary volume of disks for a database?Thank you
If there are any requirements above and beyond what is required for Pega to run (which can be found in the Pega installation guide), the AES installation guide will mention it but I don't believe there are any:
https://docs-previous.pega.com/pega-autonomic-event-services-72-installation-and-upgrade-guide
As far as database space required, that depends on things like how many nodes are being monitored and how many alerts and exceptions are being thrown by those nodes so we can't really provide an estimate. As a starting point, see what the installation guide for that version of Pega says. For example, the 7.3 guide states:
10 GB minimum initial tablespace set to auto-extend
Sberbank
RU
Great. Thank you.
