An error when connecting RPA to Pega 7
I watched Robotic Webinar: Integrating Pega 7 and RDA and now trying to integrate Pega 7 with RPA. After configuring some settings needed, Error conneting to server occurs when I click the ellipsis of Fields property.
-- can't select properties in Pega 7 shown in the webinar.
RuntimeConfig.xml
<Robotics>
<PegaServer baseUrl="http://xxxxx:9080/prweb/api/v1/" />
<LocalApiService enabled="true" SSL="false" port="9443" allowedOrigins="*" />
</Robotics>
StudioConfig.xml
<Robotics>
<RDA_Credentials userName="[email protected]" password="install" />
</Robotics>
I confirmed the user has roles PegaRULES:PegaAPI and Request URL is 'http://xxxxx:9080/prweb/api/v1/' on Pega API Help window. So the questions I'd like to ask are..
RuntimeConfig.xml
<Robotics>
</Robotics>
StudioConfig.xml
<Robotics>
</Robotics>
1. Are there something wrong about settings?
2. Pega 7 I'm using is for Lead System Architect (Beta), does this relate to the error?
Thank you.
