Cognizant
Last activity: 6 Sep 2017 8:45 EDT
How can I add new properties in JMS MDB Listener Service?
My application requires to add some additional properties in JMS MDB Listener service headers. Can that be done? I did one POC by adding the required properties in the header dropdown by privately editing the Data Transform pzInitServiceJMSParameterName. I tried to update deployment descriptor as I have added this new property in JMS header. I got the following message :
Failed to update ejb-jar.xml, generated MDB descriptor already exists in ejb-jar-xml.
Use generated fragments to manually update ejb-jar.xml.
https://home6v8-u.eu.nag.net:1456/lsapweb/PRServlet/Ggnygf-35Wye0E-SUa8s3gCr6XoL218OwWDNaTIeOve3BME-8EOFaw%5B%5B*/RSJMS/NAGLSAPMdbListener_Sync.xml?pzExpirationPeriod=0
I restarted the listener and tried to process some inbound message. I got the following error message :
com.pega.pegarules.pub.PRException: Invalid header name: userprop3
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.getHeaderConst(JMSListener.java:2588)
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.collectServiceProperties(JMSListener.java:598)
at com.pega.pegarules.integration.engine.internal.services.jms.JMSListener.setup(JMSListener.java:499)
at com.pega.pegarules.integration.engine.internal.services.listener.ListenerWrapper.launchListener(ListenerWrapper.java:151)
