Inheritance Parse XML - Rule Properties not mapped
Hello Community
I have a Problem with inheritance in Parse-XML Rule. The scenario is the following. There are two classes:
- AGB-CaseMgmt-Data-Partner
- AGB-CaseMgtm-Data-Partner-Employee
In the Partner Class there is a Parse-XML Rule with all the Partner infos and in the Class Employee is a second Parse-XML Rule which have two additional Elements to the Partner.
Now i got an XML from a service and in the XML there is the Employee Element which is an extended Partner. Means the Employee consists of the Partner and the two additional Elements of the Employee.
I added the Substitution Information on the Employee Parse Rule, but the Problem is, the Values from the Partner will not be mapped to the clipboard. The Properties are there but without a value.
How can i solve the issue?
Kind Regards and thanks for your help
Chris
