JPMorgan Chase
Last activity: 6 Sep 2017 7:18 EDT
Exporting Product file using Jenkins fails second time
Hi
I have created a product rule, for first time I was able to export the product file using Jenkins Build successfully. However when I try with the same product rule and version without any changes, subsequent builds for export are failing.
No matching Product or Application found with inputs Product Name:TestJenkins Product Version:01-01-01
Has anyone faced this kind of issue. Any thoughts?
Sam
***Updated by moderator: Lochan to create branched post***
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689979000/321c2db9-adc7-4c43-8f1d-d6a84c486e5a.jpg?itok=mEyE0RUn)
Hi Samanth,
Thanks for sharing the requested information. As per the information available in the Failure.txt log file you specified below product version,
[pega:propertyfilegenerator] jenkins-PegaDeploymentDev-16.export.productVersion=01-01-01
But if you observe the Success.txt log file the product version is 01.01.01 as shown below,
[pega:propertyfilegenerator] jenkins-PegaDeploymentDev-15.export.productVersion=01.01.01
Also if you observe your Product rule the version of product is 01.01.01 not 01-01-01
Kindly change the product version to 01.01.01 then your export will work successfully.
Regards
Mahesh
Did you find any errors in the build file log?
Kindly share the logs to further debugging
JPMorgan Chase & Company
In the configuration file in product version you need to pass the generated id instead of ruleset version. I hope it will resolve.
JPMorgan Chase
Hi
I am not passing ruleset version. When I create a product rule, say TestJenkins I am giving the product version as 01-01-01. I think it should be correct. I did not understand " you need to pass the generated id instead of ruleset version" Can you explain more on this?
Sam
Hi Samanth,
The product version is not 01-01-01, kindly check the attachment where you can find the product version. In my Jenkins Product version is 20170802.085237.
So correct the product version and try the build it will work.
Regards
Mahesh
JPMorgan Chase
Hi
Thank you for response.
Product version can be 01-01-01(attaching image FYR). There is no rule to be any specfic number. You can check the product versions given by Pega. Attaching sample. Also my question was first time it ran successfully and I got the zip file. When I run the build for same product without any changes its not working.
Sam
@Samanth - if you don't mind can you share your Product rule screenshot along with the console output of your jenkins build for further investigation.
JPMorgan Chase
Hi
Uploaded Jenkins log's for success and failure scenario. Product rule screenshot.
Sam
Hi Samanth,
Regards
Mahesh
