CYBG
Last activity: 14 Sep 2017 5:59 EDT
prbootstrap.properties finds wrong version of code?
We're attempting to update PRPC from 7.2.1 to 7.2.2. When we run the update.bat script, we get the following error:
[java] SEVERE:
[java] Aug 17, 2017 1:27:47 PM com.pega.pegarules.internal.bootstrap.PRMiniLoader
[java] SEVERE: ============================= Failed to bootstrap PegaRULES =============================
[java] SEVERE:
[java] SEVERE: Could not load the java class 'com/pega/pegarules/internal/bootstrap/phase2/PRBootstrapImpl.class' from the database table 'PRWFNPE1.pr_engineclasses'
[java] SEVERE: This is usually due to an empty 'PRWFNPE1.pr_engineclasses' table, or possibly it does not contain the configured codeset version.
[java] SEVERE: In this run the prbootstrap.properties specified 'pega-enginecode:07-10-27', checking database...
[java] SEVERE:
[java] SEVERE:
[java] ============ PegaRULES Bootstrap Configuration ============
[java] Date: Thu Aug 17 13:27:47 BST 2017
[java] Java Version: Oracle Corporation 1.8.0_60
[java] Configuration: file:/C:/Users/S514812/AppData/Local/Temp/PegaInstallTemp-15-August-2017-14.00.26/prbootstrap.properties
[java] Pega-EngineCode: 07-10-27
[java] JDBC Driver: oracle.jdbc.OracleDriver
[java] JDBC URL: jdbc:oracle:thin:@vrhogdu100.eu.nag.net:1643/PWFU.eu.nag.net
[java] JDBC User: PWFU_SYS
[java] Database: Oracle Oracle Database 11g Enterprise Edition Release Proprietary information hidden.0 - 64bit Production
[java] With the Partitioning, OLAP, Data Mining and Real Application Testing options
[java] Driver: Oracle JDBC driver Proprietary information hidden.0
[java]
[java] (!) Unable to use given database configuration
[java] (!) Unable to locate classes on filesystem
[java] =============== End Bootstrap Configuration ===============
The pzCodesetVersion for the prbootstrap.properties record in the pr_engineclasses table is 07-10-25, which I assume is correct for the version of 7.2.1 that we have installed. So why does the 7.2.2 update expect it to be 07-10-27 and throw a fit because it's not (assuming that what the above means)?
We've attempted five PRPC updates in the past few years, and only one was successful. In all other cases we had to export the code in a product file, wipe and install the new version and then import the application. Has this been the experience of any other PRPC users? Is there really an easy way to update PRPC or is the complete wipe-and-reinstall the only way to be sure?
