Can we close a work object from left nav?
Can we close a work object from lef nav. similar to the request. that the below post described.
  Hello Sriram,
Thanks for posting your query in PSC :)
In case, you are calling finish assignment, then refer the post. Also, it suggests on Close Harness.
Rincy
  I think if you set the dynamic container to single document it always closes the earlier document while creating new document. So creating new case would close the earlier case.
-Saikat
  Or you can try calling this script to close all the previous thread.
<script>
function closeDocuments(event){
pega.desktop.closeAllDocuments(event)
</script>
-Saikat
  Thanks for the options provided.
