Serialized Solutions Inc
Last activity: 15 Aug 2017 11:34 EDT
LSA 7.3 (Beta) corrupt .OVA file? Cannot import into Virtual Box
trying to import the LSA 7.3 (Beta) .OVA file into latest version of VirtualBox and I am getting the following error:
Failed to import appliance \LSA_730_VM_20170728.ova.
Could not create the imported medium \LSA_7.3.0-disk1.vmdk'.
VMDK: Compressed image is corrupted \LSA_7.3.0-disk1.vmdk' (VERR_ZIP_CORRUPTED).
Result Code: VBOX_E_FILE_ERROR (0x80BB0004)
Component: ApplianceWrap
Interface: IAppliance {8398f026-4add-4474-5bc3-2f9f2140b23e}
I have tried re-downloading this file 3 times (2 with Chrome and 1 with Opera)
has anyone else seen this problem?
thank you,
Rob
Rob,
When using IE to download, be sure to change tar extension to ova prior to download.
I'd also suggest you are ensure you are not logged into any VPN while trying to access the VM.
You might also take a look at the following thread for a suggested fix: https://collaborate.pega.com/question/failed-open-pvs-lsa-719-oracle-virtual-box
If you still have difficulty, please document screenshots along with your issue and submit to Proprietary information hidden.
Kind regards,
Bob
#helpme
just wanted to add an update. downloaded with Internet explorer and it recognized the download as a .tar. after extracting, still get the same error.
Has anyone else had any better luck?
Rob,
Kind regards,
Bob
Ravindra Mandya Girigowda
Hi @Lloyb
thank you for the response/hints. I am not using VPN. It seems I might be having an issue with my machine (and it may be tied to VirtualBox temporarily saving file [vmdx] which happens to be on a SSD drive) but still investigating.... I tried with another machine. downloaded the file with IE. Did not change name from .tar to .ova. Proceeded to "untar" and then attempted to import .ovf file. This successfully worked and I was able to import and run the VM. (don't know the centos userid /password to login but that's a separate thread.)
I will try the IE download steps on my machine to see what happens ; but it might be more related to VirtualBox and SSD issues. :(
Rob
Hi Rob,
Thanks for the question and follow-up. I'm in the process of tracking down the right SME to help.
@Maryrita
thank you. It appears we are getting closer... :)
To All. just a follow up.
I might have had some Virtual Box product issues but re-attempting with @Lloyb instructions definitely worked.
Hi Rob,
Thanks for circling back and letting the community know. Glad you were able to get the issue resolved.
