Does Pega 6.3SP1 support database mirroring?
As there is no such mention in support guide I don't think it is supported. You can verify the support guide as well.
https://collaborate.pega.com/discussion/prpc-5x-6x-platform-support-guide-easy-find
Also check below discussion
https://collaborate.pega.com/question/pega-72-support-sql-server-2014-high-availibility-options
Hope this helps.
Thank You.
Thanks! Shekhar. Looks like Pega does not support this configuration but technically, it works as long as database support automatic failover. Do you agree ?
It looks like that but it's little experimental so Pega can't provide assurance I believe.
Thank You
Here is a link to a post where customer was using Oracle golden gate. I know that there is at least one customer who uses golden gate successfully. I think there are some tables that you do not want to replicate if you are using golden gate in an active-active configuration but in general it works.
https://collaborate.pega.com/question/using-golden-gate-keep-failover-database-sync
