SMS Management & Technology
How to disable autofill for a particular input field
On iPad device we have Autofill enabled for Safari browser.
As part of application functionality, change password is one of the features for users. When this change password action is initiated by user, current password filed is being pre-populated with user's password. Is there a way I can disable this at section/harness level in Pega?
Please let me know any solutions for this.
Thanks & regards
Murali
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-02/b651f1e8-85f6-4f6e-8525-7637bcca22e9.jpg?h=1a6c0dd1&itok=gckJaKE0)
Hi Murali,
Unfortunately I don't think this is possible in PRPC, to get around this you may need to go the route of creating a custom non auto-generated control. That being said, from looking around online it looks like there might not be an easy way of doing this, it looks like adding autocomplete="off" on the input tag used to give you the behavior but might not work anymore. You may need to do something rather custom in JavaScript: https://stackoverflow.com/questions/32369/disable-browser-save-password-functionality
Meghan
![](https://accounts.pega.com/sites/default/files/pega-user-image/39/REG-38808.png?source=PUMINIT)
This needs to be tackled from browser level and not from PRPC level.
I guess you can do it like this : Safari-Preferences- Auto fill : Turn it off or on as per your need.
Hello Santanu,
Thanks for your response. I understand that by disabling auto fill on Safari preferences of iPad this could be resolved. But this also means that it gets disabled for all websites accessed on Safari. I would like to know is there a way to disable auto-fill for a specific harness/section in PRPC.
One solution I have is to use a new property with a name other than "password". But would like to know any other ways of achieving it.
Murali
vijay saidu
Found a solution on net: Trick the auto fill with a hidden element: https://www.odoo.com/forum/help-1/question/disable-autofill-on-password-field-110014 :)
Hope this will help someone facing similar issue.
But would be happy to know from others if there is a way to configure this (turning off auto fill for a section/harness) within Pega.
Regards
Murali
This trick is not working in PRPC :(
I came across DisableAutoComplete DSS/When rule that is being used in OOTB login pages (Web-Login) to turn off auto complete, but these are custom HTML rules. Is there a way to configure this in auto generated section/harness rules as well?
Murali
Hi Murali,
Meghan
Thanks Meghan for the clarification.
Regards
Murali
