Bank of America
How to select the items in a Hierarchy TreeView
How do I need to select the items of Hierarchy Tree using automations.
***Edited by moderator, Maryrita: moved to Product Support from Applications***
If the tree is dynamic then interrogate the parent and see if you can use a selectbyindex or selectbyname method. If it's static then interrogate each node and use performclick on it.
Bank of America
Can you post a screenshot of Object Explorer? Is this a web application or a Windows application? What is the type of this control? If it is being identified as a generic control, then you will not have access to those methods.
Bank of America
From the icon it appears to be a ListBox. What are the methods that you have available? Generally, there are multiple ways to select items available. The methods should start with "Select".
Bank of America
You would likely need to work with support to determine why this particular control is identified as a ListView as opposed to a Treeview. If you open an SR, please report the number here for tracking purposes.
The following article will be help you in creating an SR-
My Support Portal explained for Pega Robotic Automation (formerly OpenSpan)
Bank of America
I suggest that you open an SR with support as it appears you need someone who can look at your machine. If you do open an SR, please post the SR number here for tracking purposes.
Gridinfocom
For these tree view is there a perform right click option, and if there a perform right click can we select a option after right click?
