Gird export to PDF/Excel/CSV
I am using an activity "pzRDExportWrapper" to export a Grid to PDF/Excel that is using Report Definition as Source. I am using Section Refresh but there is an issue that the report is downloaded once. Second click doesn't work. There is an defect in Pega as per the following article.
https://pdn.pega.com/support-articles/export-excel-downloads-file-only-once
Are there any alternative to export Grid to PDF/Excel and CSV? This is very common task, I am sure there is another (better) way to achieve this. Let me know please.
Thanks in Advance.
***Edited by Moderator Marissa to add SA details***
Figured it out. The out of the box functionality is using pzPega_report_commandribbon.js
to call the same activity. Had to use the same on the button.
