How to convert a notepad to excel in openspan?
i need to convert a notepad to excel. should I write a script or is there any other method for it?
example:
custid custName
1 aaa
2 bbb
3 ccc
thanks in advance.!
You can use the Excel connector for this: http://help.openspan.com/80/Components/Microsoft_Excel.htm
Hi Aswini,
Did you get the solution?
how can we read that data from notepad and store to excel sheet in a table format.
Reading out of notepad can be done by interrogating the Notepad window. You will need to read the text line by line and then split it. You can read line by line by using the .Net StringReader. Here is a simple example of reading through the text and splitting by a space.
Add your logic at the end to do something with the data acquired on each line.
Hi Jeff,
Thanks for the reply!!
I am not using Pega_8, In openspan unable to get the control NewStringReader, please help.
Thanks in advanced.
Anil
Hi Anil,
I am also using openspan 7.1 and facing same scenario, have u got the solution for this, pls share if you have found out.
Hi Shang,
Yeah I got the solution, By Adding Constructor for type (looks like flower sysmbol,we can find it beside try catch icons) "System.IO.Streamreader" enter then select (String path) in Choose Method overload Pop up, After that i will add to your automation as well as in object explorer, Then You can do any operations with that.
Best Regards,
Anil Nalla
Where should i put the path of my notepad that is going to be converted to excel? Thanks
