NASCO
Last activity: 20 Jun 2017 14:15 EDT
XSD String embeded in XML data extract for certain properties when using GetallProperties in BIX-xsi:nil="true"
We are seeing following XSD string in XML file generated using Get all properties. We are observing these for certain pega OOTB properties only and all other properties doesn't have this string in it. So this string indicates null content for that property
We are trying to find in what scenarios does pega add this XSD string to properties. Do we have something in the property rule that says this value can be or can not be null? because for custom properties we are not seeing this string in the XML.
please find the Screen Shot attached.
Regards
Aravind
Can you elaborate exactly what your test case here ?
Are you doing a 'show-page' or something ? (I'm not sure I understand what the 'Get All Properties' mechanism is here exactly ? Or are you using an XML mapping rule etc?)
Can you include the full XML (or at least any namespace declarations there might be in the XML).
