Infosys
How to configure RDA, I see Invalid Hostname URI
I have installed Pega Robotic Studio and trying to configure Robot Activity, when I click on Fields ellipses, I see an error message
invalid uri: hostname could not be parsed. Can you help me with this issue
my prpc server is installed as PE on my laptop where the robotics studio is also installed.
RuntimeConfig.xml
RuntimeConfig.xml
<Robotics>
<!-- PegaServer tag is specific to RPA. -->
<!-- baseurl: Base address for Runtime to use for calls to request work items.-->
<PegaServer baseUrl="https://myhome:8081/prweb/api/v1"/>
<!-- LocalApiService tag is specific to RDA. -->
<!-- enabled: If true, the Runtime will self host a REST service to accept requests from the Pega application. -->
<!-- SSL: If true, the service uses SSL and must be accessed via https. -->
<!-- port: Port the service will listen on. -->
<!-- allowedOrigins: Comma delimited list of domains that the service will accept requests from. -->
<!-- A specific domain can be given (i.e. acme.pega.com) or the subdomain may be wildcarded (i.e. *.pega.com) -->
<!-- Requests from any domain not in this list will be rejected. -->
<LocalApiService enabled="true" SSL="true" port="9443" allowedOrigins="*.pega.com"/>
</Robotics>
StudioConfig.xml
<Robotics>
<!-- baseUrl: Address of Pega API endpoint -->
<PegaServer baseUrl="https://myhome:8081/prweb/api/v1/"/>
<!-- The following credentials allow Studio to authenticate with the Pega server. -->
<!-- This user has read only access Pega class and field names. -->
<!-- No other permissions are required by or granted to this user. -->
<!-- userName: User name used to authenticate with Pega server. -->
<!-- password: Password used to authenticate with Pega server. -->
<RDA_Credentials userName="---" password="---"/>
</Robotics>
Vamshi
