    CIBC
Last activity: 13 Jun 2017 14:02 EDT
the recommended way to handle the exception of data page
when using connect as the source of the data page, which one followings is the recommended way to handle the exception:
option1 - using post load activity. by determine the datapage error, do proper handle.
option2 - using the response data transform. there is pre generated "when" step in the DT when you create response DT from the data page config.
