Common Wealth Bank of Australia
Relaystate Parameter format issue in IDP initiated SSO (SAML 2.0) - PRPC 7.2.2
We are Implementing IDP initiated SSO Integration (SAML 2.0)in PRPC 722. But there seems to be some issue with the format of the RelayState parameter which is passed as a query string in the IDP url. When we pass the Pega SSO URL "https://hostname:443/prweb/sso" in the Relaystate finally it is being encoded as "https%3A%2F%2Fhostname%3A443%2Fprweb%2Fsso" and the encoded value is being set to targetlocation which results in a blank screen. When i tried to pass the Relaystate in the encoded format ""https%3A%2F%2Fhostname%3A443%2Fprweb%2Fsso"" even then the same issue persist. Please suggest a proper format to be used for the relaystate parameter.
***Moderator Edit: Vidyaranjan | Updated SR details***
