InCorrect Additional Xmltag is added to the Paragraph rules
The Highlighted is Comming for every request.Eeven though we delete and save the rule it again creating the xml tag.
Hi Sailaja,
Thanks for posting your query on PSC, This issue will occur when you use incorrect Pega When rule or Incorrect Pega reference in text editor/ source code.
Please try to remove each line to find out the issue. You can see the issue easily on toggling the source code of issue.
Request you to go through the below Support article for your reference:
https://community.pega.com/support/support-articles/tags-are-getting-misplaced-when-source-paragraph-viewed
Best regards,
Naveen
HI Naveen
This issue is happening in 6.3 environment
the when rule is used for each ebedded page.
Regards
Sailaja K
Hi Sailaja,
Thanks for the quick response, Can you remove the whenrule configured to each ebedded page and check the scenario.
Include the whenrule direct to the inline element as explained in the support article.
Best regards,
Naveen
HI
Below is the XML, we are using i bold that additional still it is comming.Could you please help me on that.
HI
<span style="FONT-FAMILY: Times New Roman"></span>
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0>
<TBODY>
<TR>
<TD style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'" width="100%" colSpan=4><pega:include type="Rule-HTML-Paragraph" name="CommonFaxHeader"></pega:include><br><span style="FONT-FAMILY: Times New Roman">RE: OP ADDITIONAL INFORMATION</span></TD></TR>
<TR>
<TD width="100%" colSpan=4>
<HR>
</TD></TR>
<TR>
<TD style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'" width="100%" colSpan=4><pega:include type="Rule-HTML-Paragraph" name="FaxMemberDOB"></pega:include></TD></TR>
<TR>
<TD style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'" width="100%" colSpan=4><span style="FONT-FAMILY: Times New Roman">Reference #: <pega:reference name="Top.pyID"></pega:reference></span></TD></TR>
<TR>
<TD style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'" width="100%" colSpan=4><br>
<P class=MsoNormal style="MARGIN: 0in 0in 0pt"><span style="FONT-FAMILY: Times New Roman; mso-bidi-font-size: 12.0pt">Per your <pega:reference name="Top.ServiceTypeCode"></pega:reference>request for:<?xml:namespace prefix = "pega" /><pega:forEach name="Top.RequestLineItems"><pega:reference name="$THIS.Code" mode="literal"></pega:reference>, </pega:forEach></span><span style="FONT-FAMILY: Times New Roman"><span style="FONT-FAMILY: ; mso-bidi-font-size: 12.0pt">please call <pega:reference name="Top.FaxHeaderBodyPh(1)"></pega:reference></span><span style="FONT-FAMILY: ; mso-bidi-font-size: 12.0pt"> or fax the following additional information:</span></span></P>
<DIV style="mso-element: comment-list">
<DIV style="mso-element: comment">
<DIV id=_com_1 class=msocomtxt language=JavaScript>
<P class=MsoCommentText style="MARGIN: 0in 0in 0pt"><span style="FONT-FAMILY: Times New Roman" size="2"></span><span style="FONT-FAMILY: Times New Roman" size="2"></span> </P></DIV></DIV></DIV></TD></TR>
<TR>
<TD style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'" width="100%" colSpan=4><pega:reference name="Top.AdhocFaxContent"></pega:reference><br><br><br><br><span style="FONT-FAMILY: Times New Roman">Thank You,<br></span><pega:reference name="Top.FaxTemplate_from"></pega:reference><br><br><br></TD></TR>
<TR>
<TD style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'" width="100%" colSpan=4> <pega:when name="IsTandigmUser"><pega:include type="Rule-HTML-Paragraph" name="TDMFaxTemplateDisclaimer"></pega:include></pega:when><br><br></TD></TR></TBODY></TABLE>
