Accenture
Last activity: 10 Oct 2017 15:40 EDT
Case Type rule Should be in Fw layer or Impl layer?
in ECS class structure, most of the rules we keep in the Framework layer, and some of the rules which need specialization we bring to Implementation layer. We keep work class both in FW layer and Impl layer, because to pint different work table.
now question is for Case Type rule, assume there is no requirement of specialization in the case type rule for Impl layer, then what is the best practice?
whether same case type rule should be in both FW and IMPL layer
or
only FW layer.
Regards
Shankha
The best practice will be to keep casetypes in impl layer. It will give you provision of accomodating business changes quickly .
