Cognizant
Last activity: 9 Jun 2017 4:45 EDT
Delete the TGB
By mistake i have deleted the TGB(by Login to Administrator->Click on Designer Studio -> System -> Refactor -> Classes and then deleted all the TGB classes) , Now I am not able to login to the SA@TGB, Is there any way to login.
Thanks.
***Edited by moderator, Maryrita: Moved from Applications to Product Support Community***
Instellars
Hi Shashank,
You can try using Rule-.RecoverHistory activity . You will need to pass the history handle of the deleted class to the activity before running it.
Infosys
Thanks for your reply, but the thing is currently I am not able to login to SA@TGB, So how the activity can be run.
Thanks in advance.
Virtusa
Hi Kapil,
Have you taken a backup of the db, before performing the delete? Restoring the backup should help.
Madhuri
Infosys
No Madhuri, I didn't take the backup..
Any Other way.
Thanks.
Virtusa
Hi Kapil,
Apologies, my miss. The wizard creates a backup of the deleted class in the ServiceExport directory. The file is named with
the class name and with “_DELETE” appended and can be imported using the import tool. Can you please try the same?
Madhuri
Virtusa
If you are using tomcat, you would find it at the location: C:\Tomcat722\temp\StaticContent\global\ServiceExport
Please let me know if this was of help.
Madhuri
Infosys
Hi Madhuri,
I am not using the tomcat, I am doing all these thing on the pega cloud which is provided in the PDN.
Virtusa
Hi Kapil,
In that case, you will have to follow up with the Pega cloud team to get the deleted class back. If you are doing this for a course, you should have to re-download the system and re-do the exercises, or check with the pega academy team.
Madhuri
