Anyone integrated with Jenkins for automate deployment in Pega 7.2
Anyone integrated with Jenkins for deployment automation in Pega 7.2 and give me outline how to configure.
I have try to use "prpcServiceUtils", didnt work well.
Anandh
Please take a look at step by step guide - Using prpcServiceUtils and Jenkins for automated application deployment
Hi Dilip,
I have gone through that article, that didnt have much information. I have configure those step, but didnt mention about those source and destination configuration and other details.
Anandh
Can you enlighten us with the exact issue which you are facing post following the guide, so that any of us can try to help you?
Hi Dilip,
What are those parameter need to update on the "prpcServiceUtils.properties" file before using this utility?
Anandh
I have followed the same step as mentioned in the article, but Im getting the below error when I execute the build.
Started by user Anandh Palanisamy
[EnvInject] - Loading node environment variables.
[EnvInject] - Preparing an environment for the build.
[EnvInject] - Keeping Jenkins system variables.
[EnvInject] - Keeping Jenkins build variables.
[EnvInject] - Injecting as environment variables the properties content
TargetUser=user
SystemName=$BUILD_TAG
SourcePassword=password
SourceHost=http://wwwdev.xxxxxxx/prweb/PRServlet
TargetPassword=user
TargetHost=http://wwwdev.xxxxxprweb/PRServlet
SourceUser=password
ParameterName=Value
[EnvInject] - Variables injected successfully.
[EnvInject] - Injecting contributions.
Building in workspace C:\Anandh\Project\DevOps
[jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -DproductVersion=01.01.01 -DproductName=FordRuleset exportprops && exit %%ERRORLEVEL%%"
Unable to locate tools.jar. Expected to find it in C:\Program Files\Java\jre7\lib\tools.jar
Buildfile: C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\samples\jenkins\Jenkins-build.xml
TargetUser=user
TargetPassword=user
SourceUser=password
ParameterName=Value
exportprops:
[length] C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\samples\jenkins\FordRuleset does not exist
[propertyfile] Creating new property file: C:\Anandh\Project\DevOps\jenkins-SampleBuild-12_export.properties
BUILD SUCCESSFUL
Total time: 0 seconds
[DevOps] $ cmd /c call C:\Users\APALANIS\AppData\Local\Temp\hudson5132555301835811341.bat
C:\Anandh\Project\DevOps>\scripts\utils\prpcServiceUtils.bat export --connPropFile C:\Anandh\Project\DevOps\jenkins-SampleBuild-12_export.properties --artifactsDir C:\Anandh\Project\DevOps
The system cannot find the path specified.
C:\Anandh\Project\DevOps>exit 3
Build step 'Execute Windows batch command' marked build as failure
Finished: FAILURE
Can you someone help me on this.
Anandh
Im getting the below exception on the jenkin build. Can you please someone help me on this,
Started by user Anandh Palanisamy [EnvInject] - Loading node environment variables. [EnvInject] - Preparing an environment for the build. [EnvInject] - Keeping Jenkins system variables. [EnvInject] - Keeping Jenkins build variables. [EnvInject] - Injecting as environment variables the properties content TargetUser=apalanis SystemName=$BUILD_TAG SourcePassword= SourceHost=http://xxx.xx.xx TargetPassword= TargetHost=http://xxx.xx.xx SourceUser=apalanis ParameterName=Value [EnvInject] - Variables injected successfully. [EnvInject] - Injecting contributions. Building in workspace C:\Anandh\Project\DevOps [jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -DproductVersion=01-01-01 -DproductName=TestProduct exportprops && exit %%ERRORLEVEL%%" Unable to locate tools.jar. Expected to find it in C:\Program Files\Java\jre7\lib\tools.jar Buildfile: C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\samples\jenkins\Jenkins-build.xml exportprops: [length] C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\samples\jenkins\TestProduct does not exist [propertyfile] Creating new property file: C:\Anandh\Project\DevOps\jenkins-SampleBuild-21_export.properties BUILD SUCCESSFUL Total time: 0 seconds [DevOps] $ cmd /c call C:\Users\APALANIS\AppData\Local\Temp\hudson7320348297634750539.bat C:\Anandh\Project\DevOps>C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils\prpcServiceUtils.bat export --connPropFile C:\Anandh\Project\DevOps\jenkins-SampleBuild-21_export.properties --artifactsDir C:\Anandh\Project\DevOps Invoke our ant script, passing in the arguments as collected Unable to locate tools.jar. Expected to find it in C:\Program Files\Java\jre7\lib\tools.jar Buildfile: C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils\prpcserviceutilsWrapper.xml [echo] *** JVM Arguments -Xmx1280m -XX:MaxPermSize=512m *** -init: [delete] Deleting directory C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils\generated [mkdir] Created dir: C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils\generated [pega:propertyparser] Reading Properties from : C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils/prpcServiceUtils.properties [pega:propertyparser] pega.rest.server.url=http://<host name>:<port number>/<context>/PRRestService/<tenant url hash> [pega:propertyparser] pega.rest.username= [pega:propertyparser] pega.rest.password=***** [pega:propertyparser] pega.rest.proxy.host= [pega:propertyparser] pega.rest.proxy.port= [pega:propertyparser] pega.rest.proxy.username= [pega:propertyparser] pega.rest.proxy.password=***** [pega:propertyparser] pega.rest.proxy.domain= [pega:propertyparser] pega.rest.proxy.workstation= [pega:propertyparser] pega.rest.response.type=xml [pega:propertyparser] user.temp.dir=C:/pega_temp [pega:propertyparser] export.archiveName= [pega:propertyparser] export.productName= [pega:propertyparser] export.productVersion= [pega:propertyparser] export.applicationVersion= [pega:propertyparser] export.applicationName= [pega:propertyparser] export.async=true [pega:propertyparser] expose.includedClasses= [pega:propertyparser] expose.includeDescendents=true [pega:propertyparser] expose.excludedClasses= [pega:propertyparser] expose.excludeDescendents=true [pega:propertyparser] expose.startKey= [pega:propertyparser] expose.endKey= [pega:propertyparser] expose.startDate= [pega:propertyparser] expose.endDate= [pega:propertyparser] expose.reindex=true [pega:propertyparser] expose.reindexType=nonpega [pega:propertyparser] expose.commitRate=100 [pega:propertyparser] expose.async=true [pega:propertyparser] import.archive.path= [pega:propertyparser] import.mode=import [pega:propertyparser] import.existingInstances=skip [pega:propertyparser] import.nofailonerror=false [pega:propertyparser] import.commitRate=100 [pega:propertyparser] import.compileLibraries=true [pega:propertyparser] import.allowImportWithMissingDependencies=false [pega:propertyparser] import.codesetName=Customer [pega:propertyparser] import.codesetVersion=06-01-01 [pega:propertyparser] import.async=true [pega:propertyparser] import.trackData=false [pega:propertyparser] manageTrackedData.operation= [pega:propertyparser] hotfix.operation= [pega:propertyparser] hotfix.dlFilePath= [pega:propertyparser] hotfix.catalogPath= [pega:propertyparser] hotfix.bypassSchema=false [pega:propertyparser] hotfix.force=false [pega:propertyparser] hotfix.async=true [pega:propertyparser] getstatus.jobID= [pega:propertyparser] getstatus.operationName= [mkdir] Created dir: C:\Users\APALANIS\AppData\Local\Temp\PegaInstallTemp-05-May-2017-13.20.07 [pega:hasenoughspace] Found 58393784KB of free space on 'C:\Users\APALANIS\AppData\Local\Temp\' -processInstances: [echo] Performing export on multiple instance(s) [echo] argument line [echo] -action export -propFileDir C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir C:\Users\APALANIS\AppData\Local\Temp\/PegaInstallTemp-05-May-2017-13.20.07 -artifactsDir C:\Anandh\Project\DevOps [echo] Reading connection information from C:\Anandh\Project\DevOps\jenkins-SampleBuild-21_export.properties [pega:propertyfilegenerator] pega.rest.server.url=http://<host name>:<port number>/<context>/PRRestService/<tenant url hash> [pega:propertyfilegenerator] pega.rest.username= [pega:propertyfilegenerator] pega.rest.password=***** [pega:propertyfilegenerator] pega.rest.proxy.host= [pega:propertyfilegenerator] pega.rest.proxy.port= [pega:propertyfilegenerator] pega.rest.proxy.username= [pega:propertyfilegenerator] pega.rest.proxy.password=***** [pega:propertyfilegenerator] pega.rest.proxy.domain= [pega:propertyfilegenerator] pega.rest.proxy.workstation= [pega:propertyfilegenerator] pega.rest.response.type=xml [pega:propertyfilegenerator] user.temp.dir=C:/pega_temp [pega:propertyfilegenerator] export.archiveName= [pega:propertyfilegenerator] export.productName= [pega:propertyfilegenerator] export.productVersion= [pega:propertyfilegenerator] export.applicationVersion= [pega:propertyfilegenerator] export.applicationName= [pega:propertyfilegenerator] export.async=true [pega:propertyfilegenerator] expose.includedClasses= [pega:propertyfilegenerator] expose.includeDescendents=true [pega:propertyfilegenerator] expose.excludedClasses= [pega:propertyfilegenerator] expose.excludeDescendents=true [pega:propertyfilegenerator] expose.startKey= [pega:propertyfilegenerator] expose.endKey= [pega:propertyfilegenerator] expose.startDate= [pega:propertyfilegenerator] expose.endDate= [pega:propertyfilegenerator] expose.reindex=true [pega:propertyfilegenerator] expose.reindexType=nonpega [pega:propertyfilegenerator] expose.commitRate=100 [pega:propertyfilegenerator] expose.async=true [pega:propertyfilegenerator] import.archive.path= [pega:propertyfilegenerator] import.mode=import [pega:propertyfilegenerator] import.existingInstances=skip [pega:propertyfilegenerator] import.nofailonerror=false [pega:propertyfilegenerator] import.commitRate=100 [pega:propertyfilegenerator] import.compileLibraries=true [pega:propertyfilegenerator] import.allowImportWithMissingDependencies=false [pega:propertyfilegenerator] import.codesetName=Customer [pega:propertyfilegenerator] import.codesetVersion=06-01-01 [pega:propertyfilegenerator] import.async=true [pega:propertyfilegenerator] import.trackData=false [pega:propertyfilegenerator] manageTrackedData.operation= [pega:propertyfilegenerator] hotfix.operation= [pega:propertyfilegenerator] hotfix.dlFilePath= [pega:propertyfilegenerator] hotfix.catalogPath= [pega:propertyfilegenerator] hotfix.bypassSchema=false [pega:propertyfilegenerator] hotfix.force=false [pega:propertyfilegenerator] hotfix.async=true [pega:propertyfilegenerator] getstatus.jobID= [pega:propertyfilegenerator] getstatus.operationName= [pega:propertyfilegenerator] jenkins-SampleBuild-21.pega.rest.server.url=http://xxx.xx.xx [pega:propertyfilegenerator] jenkins-SampleBuild-21.pega.rest.username=apalanis [pega:propertyfilegenerator] jenkins-SampleBuild-21.pega.rest.password=***** [pega:propertyfilegenerator] jenkins-SampleBuild-21.export.archiveName=-.zip [pega:propertyfilegenerator] jenkins-SampleBuild-21.export.productName=TestProduct [pega:propertyfilegenerator] jenkins-SampleBuild-21.export.productVersion=01-01-01 [pega:propertyfilegenerator] jenkins-SampleBuild-21.export.applicationName= [pega:propertyfilegenerator] jenkins-SampleBuild-21.export.applicationVersion= [pega:propertyfilegenerator] jenkins-SampleBuild-21.export.async=false [pega:propertyfilegenerator] jenkins-SampleBuild-21.pega.rest.response.type=xml [pega:propertyfilegenerator] Systems Configured [pega:propertyfilegenerator] jenkins-SampleBuild-21 [pega:propertyfilegenerator] Generated C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils\generated\jenkins-SampleBuild-21.prpcServiceUtils.properties [echo] *** JVM Arguments -Xmx1280m -XX:MaxPermSize=512m *** _callService: [java] 13:20:09.130 [main] INFO [a.pegarules.serviceclient.ClientSettings] - -action export -propFileDir C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir C:\Users\APALANIS\AppData\Local\Temp\/PegaInstallTemp-05-May-2017-13.20.07 -artifactsDir C:\Anandh\Project\DevOps [java] 13:20:09.140 [main] INFO [a.pegarules.serviceclient.ClientSettings] - Setting Thread Pool Size to default 5 [java] 13:20:09.140 [main] INFO [a.pegarules.serviceclient.ClientSettings] - Setting Request TimeOut to default 300 [java] 13:20:09.140 [main] INFO [.pega.pegarules.serviceclient.ClientMain] - Initializing client Current Operation = EXPORT; Thread Pool Size = 5; RequestTimeOut = 300; TemporaryDirectory = C:\Users\APALANIS\AppData\Local\Temp\/PegaInstallTemp-05-May-2017-13.20.07 [java] 13:20:09.150 [main] INFO [viceclient.requestmanager.RequestManager] - Initializing Request Manager [java] 13:20:09.150 [main] INFO [viceclient.requestmanager.RequestManager] - Initializing ExecutorService with pool size 5 [java] 13:20:09.160 [main] INFO [viceclient.requestmanager.RequestManager] - Performing EXPORT with params [System Name = jenkins-SampleBuild-21 Parameters = {hotfix.async=true, expose.includeDescendents=true, getstatus.jobID=, export.async=false, expose.async=true, expose.excludedClasses=, export.productName=TestProduct, import.commitRate=100, expose.commitRate=100, import.existingInstances=skip, user.temp.dir=C:/pega_temp, expose.reindex=true, hotfix.operation=, expose.excludeDescendents=true, pega.rest.proxy.password=, import.nofailonerror=false, export.applicationVersion=, import.codesetVersion=06-01-01, pega.rest.proxy.username=, expose.includedClasses=,http://xx.xx.xx.xx pega.rest.server.url=http://xx.xx.xx.xx, expose.startKey=, expose.reindexType=nonpega, import.codesetName=Customer, pega.rest.password=Welcome@1, import.async=true, import.compileLibraries=true, hotfix.force=false, export.productVersion=01-01-01, import.allowImportWithMissingDependencies=false, pega.rest.username=apalanis, getstatus.operationName=, expose.endDate=, pega.rest.proxy.port=, pega.rest.proxy.workstation=, expose.endKey=, import.archive.path=, hotfix.dlFilePath=, export.archiveName=-.zip, import.mode=import, expose.startDate=, manageTrackedData.operation=, hotfix.bypassSchema=false, hotfix.catalogPath=, pega.rest.proxy.domain=, import.trackData=false, export.applicationName=, pega.rest.response.type=xml, pega.rest.proxy.host=}] [java]
[java] 13:20:11.372 [pool-2-thread-1] INFO [egarules.serviceclient.rest.RestResponse] - jenkins-SampleBuild-21: Parsing response [java] 13:20:11.372 [pool-2-thread-1] INFO [egarules.serviceclient.rest.RestResponse] - jenkins-SampleBuild-21: Parsing response of length 1336 [java] 13:20:11.382 [pool-2-thread-1] INFO [egarules.serviceclient.rest.RestResponse] - jenkins-SampleBuild-21: Parsing content of type text/html; charset=ISO-8859-1 [java] 13:20:11.412 [main] INFO [viceclient.requestmanager.RequestManager] - Request on system jenkins-SampleBuild-21 failed [java] [java] Exception in thread "main" Operation EXPORT failed on jenkins-SampleBuild-21, [java] at com.pega.pegarules.serviceclient.ClientMain.executeAndHandleResponse(ClientMain.java:116) [java] at com.pega.pegarules.serviceclient.ClientMain.main(ClientMain.java:61) [java] FAILED JOBS [java] -------------------------------------------------------------------------------------------- [java] [java] System Name : jenkins-SampleBuild-21 [java] Job ID : [java] Status : [java] Error Messages : HTTP/1.1 404 Not Found [java] -------------------------------------------------------------------------------------------- [java] 13:20:11.452 [main] INFO [viceclient.requestmanager.RequestManager] - Shutting down executor service [java] 13:20:11.452 [main] INFO [viceclient.requestmanager.RequestManager] - Executor Service shutdown completed BUILD FAILED C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils\prpcserviceutilsWrapper.xml:172: The following error occurred while executing this line: C:\Anandh\Project\DevOps\prpcServiceUtils\scripts\utils\prpcserviceutilsWrapper.xml:190: Java returned: 1 Total time: 4 seconds Exiting with Error Build step 'Execute Windows batch command' marked build as failure
Finished: FAILURE
Anandh
Hi Anandh,
Your REST server name has not been set, so you get a 404 - not found.
The log output shows what you have:
If you put the correct url then this should solve your problem.
David.
Hi David,
I have checked those web.xml entry , i have the below entry.
<servlet-mapping>
<servlet-name>WebRestService</servlet-name>
<url-pattern>/PRRestService/*</url-pattern>
</servlet-mapping>
Do i need to check anything else, im using 7.2 to run this utility.
Anandh
I found the issue and solution on the above issue, there is one issue on the prpcServiceUtils it will move the whole application only. Don't have a option to move ruleset alone.
Pega should come up with utility can used for ruleset move also.
Anandh
Hi Anand,
Which version of pega 7.x your using for the automation.
have you tried using prpcutils for CICD or it is not possible.
Hi Anand,
Yes, prpcServiceUtils it will move the application only.
