Virtusa
LK
Unable to download the CSV file from server path and open blank in excel format
This issue is available in Pega 7.2.2 version and works as expected in Pega 7.1.7 version.
The CSV file is created using the Connect-File method and saved in Remote Server location (file://web:/Reports/). When the generated csv file is opened in remote location, data is available as expected. But when try to download the generated CSV file from the application, the content is not available. Here the file is downloaded with the correct file name that need to be downloaded. But the data is missing.
The Java code which is used to download the CSV file from the server path is given below.
String fileName = tools.getParamValue("FileName");
if (fileName == null || fileName.length() == 0) {
return true; // Nothing to download
boolean bDeletefile = Boolean.valueOf(tools.getParamValue("DeleteFile")).booleanValue();
String filePath="file://web:/Reports/";
pega_rules_default.downloadFile(com.pega.pegarules.pub.util.StringUtils.concat(com.pega.pegarules.pub.util.StringUtils.ASIS, filePath, fileName), tools, bDeletefile);
For further details and screen shots please refer the attached document.
Thanks!
