standard chartered
MY
Last activity: 30 Mar 2017 0:45 EDT
AES for PEGA 7.2.2
Which AES version should be installed to a PEGA 7.2.2 platform?
As per the below doc AES 7.1 is supported for PRPC 7.2.2
https://community.pega.com/documents/autonomic-event-services-aes-71-installation-and-upgrade-guide
" AES 7.1 requires PRPC 7.1 or higher. If you a running a previous version of PRPC,upgrade to PRPC 7.1. "
The release note for AES 7.2 is not yet released.You can refer below link for the features of AES 7.2
https://collaborate.pega.com/question/autonomic-event-services-aes-72-release-notes-0
Sudhish OP
Instellars
Pega recommends using AES 7.2 with Pega 7.2.2 platform.
standard chartered
MY
is AES 7.1 version is compatible for Pega 7.2.2 platform?what is the enchanced features in AES 7.2?
Sudhish OP
standard chartered
MY
Does it means that we can't install/use AES 7.2 yet?
No, you can install and use it. Refer below link for the installation/upgrade guide document released for AES 7.2.
https://pdn.pega.com/documents/autonomic-event-services-aes-installation-and-upgrade-guide-72
NASCO
I am not sure that I have seen this specific question answered... Can AES 7.1 installed on PRPC 7.1.8, be used to monitor Pega/PRPC 7.2.2 applications?
This comment has been branched out as a new node and the new thread can be followed here
![](https://accounts.pega.com/sites/default/files/pega-user-image/209/REG-209263.png?source=PUMINIT)
Your question seems to be address a query different from the topic discussed here. To gather better visibility for your question, I have branched it to create a new question. You may continue your conversation on this thread: https://collaborate.pega.com/question/can-aes-71-installed-prpc-718-be-used-monitor-pegaprpc-722-applications
Hope the information is helpful.
Thanks!
