Interrogation in Chrome browser
Hi All
I've tried to interrogate some pages in universal web application via Chrome browser, but seems like it can't get html from chrome...
When I click and drag into any items it page such as input, button, it doesn't recognize it at all....
Please kindly help how I can interrogate items in Chrome browser....
Hi Yodeh
Can you please explain how to insure that OpenSpan Chrome extension is enabled?
Hi Shilpa,
Please take a look at this PDN Article: How do I install and update the Chrome extension?
- Open Chrome to enable the extension. You will see a message in Chrome’s top, right corner to which you must respond.
- You can also open Chrome and use the Settings > Extensions option to make sure Studio is listed.
Hope this helps!
I am also facing same problem
I didn't set default browser
please help me out
Hello!
Since this post has already been marked with a Correct Answer and that doesn't apply to you, please create a new post so that you can get the response that is needed.
When you've created a new reply, please come back here and reply with the thread.
Thank you,
You did not install the extension. The extension is installed when you install Pega Robotics. There is a radio button to select to install it. You will need to re-install Pega Robotics and select the radio button to install it for Chrome.
Thanks Vegam for the reply,
I am usng 7.1.93 version of Openspan studio, while installing i had checked the check boxes of CHROME AND FIRE FOX extensions.
But still not able to interrogate. please help to me regarding this.
Raja
If you go to the installation folder for openspan, do you see a folder for 'Extensions'? The install files should be in there and you can drag the .crx file onto the chrome extensions window and it should manually install it.
