IP Address is not comming for CSSA 7.2 Course
IP address is not coming while opening the CSSA 7.2 Course either in virtual box or VMware to open that link. Please help me to find the IPaddrss for the same. Please see the attached file.
Ramakrishna Abburi
SG
Can you try to configure the network to make use of NAT and ensure that it is connected? You can also try other options like Bridged mode or Host-only. But most important make sure the virtual network adapter is enabled and connected.
TD Bank
I am also facing the same issue. I tried all different network configuration (Bridged mode or Host-only) but nothing works.
BlueRose Technologies
Me too facing same issue. Any solutions to overcome this?
Elastic
DE
there is no general workaround that works for everyone. Better send your inquiry to [email protected]
Pegasystems
in my case i set the network setting to NAT, and the VM was assigned an IP address upon restart.
Host Only worked for me.
National Australia Bank Ltd
So basically its a lottery - great - I will keep trying varying combos. Nice if the instructions where a bit more concise, hoping the software itself is a better better
Elastic
DE
Just follow the setup instructions and if needed contact [email protected] with details
