accenture
Last activity: 3 Feb 2017 9:43 EST
Check box is not visible in grid repeat layout with Pagination (Issue exists only in 7.1.8)
I have created a repeating grid layout ( With 1 to x Pagination) one of the columns is a check box. check box mode is set to editable. But at runtime check box is not visible.
Check boxes are appearing for same grid loyout works fine in Pega 7.1.3, 7.1.7, 7.2 facing issue in only 7.1.8.
Any suggestion/ is it issue with pega code?
