Pega project from scratch - Initial Setup
Application has to be develop from scratch.could you please share any documents if you have
Pega Version: 7.1.6, need details how application server,DB pega initital setup is done(Pega has to connect to hadoop(scala) application to get the data).
kindly do let me know,if you need any other information.
Rajkumar
Hi Rajkumar,
Kindly let me know this is what you are looking for? . Refer section PRPC 7.1.6 — August 11, 2014.
Also,have a look into the support guide attached for PRPC 7X version.
Hi Rajkumar,
PFA file containing details steps of installation of PRPC with Tomcat server and DB scripts as well.
Step 1: Create the user and schema
create tablespace PRPC716 logging datafile 'E:\app\hasam\oradata\PRPCDB\PRPC716.dbf' size 50M autoextend on next 1280K maxsize unlimited extent management local segment space management auto;
create user PRPC716 identified by PRPC716 default tablespace PRPC716 quota unlimited on PRPC716;
GRANT CONNECT,RESOURCE TO PRPC716;
GRANT Create view to PRPC716;
GRANT CREATE PUBLIC SYNONYM TO PRPC716 ;
GRANT DROP PUBLIC SYNONYM TO PRPC716 ;
GRANT CREATE SYNONYM TO PRPC716 ;
GRANT CREATE SEQUENCE TO PRPC716 ;
GRANT CREATE PROCEDURE TO PRPC716 ;
GRANT CREATE SESSION TO PRPC716 ;
GRANT CREATE TABLE TO PRPC716 ;
GRANT CREATE ANY TRIGGER TO PRPC716 ;
GRANT EXECUTE ANY PROCEDURE TO PRPC716 ;
GRANT READ, WRITE ON DIRECTORY DATA_PUMP_DIR to PRPC716;
Step 2: Run the wizard
java -jar PRPC_Setup.jar
Write your driver name. For ex:- oracle.jdbc.OracleDriver
File where ojdbc jar is stored. For ex:- C:\<YourFolderName>\product\11.2.0\dbhome_1\jdbc\lib\ojdbc6.jar
jdbc:oracle:thin:@//localhost:1521/prpc
Hi Rajkumar,
Enter schema name, username and password. As we have created schema with username/password is PRPC716 You can enter PRPC716 in remaining fields
Finish the wizard without any changes
Step 3: Application server configuration
- Open C:\<YourFolderName>\tomcats\apache-tomcat-ML716\bin\setEnv.bat
set JAVA_OPTS=-Xms768m -Xmx768m -XX:PermSize=64m -XX:MaxPermSize=256m -
Djava.awt.headless=true
- Go to server.xml
<Connector enableLookups="true"/> enable it
Note : Dont do this step as we face some issue during server startups
- Go to context.xml
<Manager pathname="" /> uncomment it
Error: Jul 19, 2013 2:37:46 PM org.apache.catalina.session.StandardManager doLoad SEVERE:
ClassNotFoundException while loading persisted sessions:
java.lang.ClassNotFoundExceptioncom.pega.pegarules.session.internal.authorization.ContextMap
DiagCallback
java.lang.ClassNotFoundException:
com.pega.pegarules.session.internal.authorization.ContextMapDiagCallback
- Add JDBC Resource,
<Resource name="jdbc/PegaRULES"
type="javax.sql.DataSource"
username="PRPC716"
password="PRPC716"
driverClassName="oracle.jdbc.OracleDriver"
maxIdle="2"
maxWait="5000"
url="jdbc:oracle:thin:@localhost:1521:PRPC"
maxActive="20"
connectionProperties="oracle.jdbc.V8Compatible=true;"/>
- Add temp directory,
<Environment name="url/initialization/explicittempdir" value="C:/Installation/tomcats/apache-tomcat-ML716/temp" type="java.lang.String" />
- Configure roles in tomcat-users.xml file
<role rolename="admin-gui"/>
<role rolename="manager-gui"/>
<role rolename="PegaDiagnosticUser"/>
<user username="admin" password="admin" roles="admin-gui,manager-gui,PegaDiagnosticUser"/>
- Note down tomcat port in server.xml,
<Connector port="8089" protocol="HTTP/1.1" connectionTimeout="20000" redirectPort="8444" />
- Deploy the prweb.war file into tomcat instance using its manager apps
- Stop the tomcat server and delete the prweb.war file in webapps folder
Step 4: Login into the application
http://localhost:8089/prweb/PRServlet/
administrator@pega.com install
Step 5: Post installation steps
- In designer studio, System > Settings > URLs
http://localhost:8089/prhelp
http://localhost:8089/prsysmgmt
Kindly notify, if it helps.
Asif
Thank you very much Asif.I will let you kow if anything more needed.
Rajkumar.
Hi RajKumar,
My suggestion would be once you decide which Server and Database to use, then you can refer the specific installation guide as the configuration details will be explained clearly about your choosed database and server details over here for 7.1.6 installation. If you want to know the types of Servers/databases supported by Pega, kindly go through the Product support guide over here.
Hope this information might be helpful to you.
Regards
Mahesh
