PT ASURANSI SIMAS JIWA
ID
Last activity: 24 Jan 2017 20:28 EST
Set property from Report Definition
#HelpPegaExpert!
I have report definition source from database. i want to set all the value in report definition to my property(pyWorkPage). Is there any solution for my case?
Sorry about my english
thanks before
Adri Hilda
Hi Adrihildas,
I tried an approach to achieve your functionality with a sample use case, kindly look into the attachment and let me know if that helped you.
Regards
Mahesh
Infosys
Specify the name of the page where the results are to be populated on the parameter pyPageName while executing activity pxRetrieveReportData to fetch results
Areteans Technology Solutions
Am not getting the requirement exactly, but if you want to report on the data associated with a class, you need to create an RD rule on the class and have the properties of the class as the columns in the RD rule.
Since you mentioned Database, i am guessing that the DB might be associated with a class. So make sure the columns of the DB are mapped to corresponing properties in the external mapping tab of the class rule and also check for the Database Table rule that maps the class with the external table.
Once the above check is done, you can proceed to create a Report definition rule to report on the records of the Database table.
Let us know you require help on specifics.
Ratan Balaji
ID
Ratajan Balaji thanks for reply
my requirment is like the word i attach below
Hi Adri,
As per your attachment it looks like you are fetching the data from the database into the report definition. Now you created the PageList which contains same property names in the another class and you want to initialise the data available in the report definition into the Page List which is available in different class. Kindly let us know the version of pega, so that we can try an use case if this is your exact requirement.
Regards
Mahesh
ID
hai mahesh86 thanks for reply
i use pega 7.1.2 for development so many many thanks mahesh86 :)
Hi Adrihildas,
Regards
Mahesh
ID
thanks mahesh86 thats very helping me :)
my requirment is when i run my case, send parameter to report definition the result of report definition automate set property in my pyWorkPage
example: set property id to 25, the value of id base on report definition result.
Hi Adrihildas,
If you dont mind could you please share the screenshots of your use case along with your requirement to achieve, so that it can be more clear to understand you exact requirement. Thank you.
Regards
Mahesh
ID
Mahesh86 sorry i late to reply :)
thanks for helping me i attach my requirment with screenshot in Word
Regards
Adri
