Cognizant
Last activity: 30 Jan 2017 2:24 EST
Unable to Add new nodes to Email Listenr
We are unable to add new nodes to email listeners. While try to adding new nodes getting below error message.
Error Message : "The page contains an undefied property : pyKeepMessagesonserver validation failed".
Appricicate your help.
SUmanth
***Updated by moderator: Lochan to update Categories; added SR details***
Cognizant
Hi ,
Received HFix from PEGA Systems.
Hfix-9175
SR-B13079 and SR-B12910
Sumanth
Areteans
Hi Sumanth,
I believe you are adding the Node to email listener as mentioned in the below screenshot,
Once you get error message, Open clipboard -> goto page where the error is seen -> Edit the property which is throwing error and make it empty -> Save the Page and Now in designer studio and try to save the Listener.
Cognizant
Hi deva,
Thanks for your reply.
Currently i am using PEGA 6.1 sp2 and i couldn't able to see any clipbord page related to email listener.
Please help me on this.
Note: PEGA 7 applicatios i am able to see email listener page in clipboard.
SUmanth
PEG
Issue could be checking of "Keep messages on server (IMAP)" checkbox in Email Listener data instance. Please uncheck the same and try to add the node.
Cognizant
Hi Gangabau,
In Lower env(Dev,SIT,UAT),we are able to see "Keep messages on server (IMAP)" checkbox in Email Listener data instance. But prodcution env,we are unable to see this checkbox.
There are more than 300 email listeners are there.for all listeners this checkbox is not available. without this checkbox also,we are able to add new nodes to email listeners.But only 3 emaillisteners we are unable add new nodes and getting this error "pykeepmessagesonserver" validation failed.
Note: I am not sure,why this checkbox not there in only prodcution env.
SUmanth
Cognizant
Not received correct information yet. If anyone knows correct answer. Please respond.
Sumanth
Hi Sumanth,
Do you see this issue in development environment too? can you please check and do following:
"With regards to this issue, please check Data-Admin-Connect-EmailListener.pyDefault model rule in your environment. See if this property pyKeepMessagesOnServer is being initialized there. If it is, you can save the model in a custom ruleset and delete that step."
Cognizant
Hi ,
Hfix-9175
Sumanth
Hi Sumanth,
Thank you for updating your post with the solution.
Community members,
Please raise an SR to receive this HFix. Refer the steps given here: Raising Support Requests for Hotfixes now made easy!
Lochan | Community Moderator | Pegasystems Inc.
