Generated DDL script is failing saying "java.lang.UnsupportedClassVersionError: com/pega/pegarules/util/anttasks/Uppercase : Unsupported major.minor version 51.0"
FYI : Installing Pega 7.2.1 using Tomcat 8 and PostgreSQL 9.3
Java version is 8
./generateddl.sh --action install --dbSchema test --outputDirectory /root/Downloads/pega/scripts/temp
Generating install ddl...
Buildfile: ./setupDatabase.xml
BUILD FAILED
Could you please re-verify the JDK version under JAVA_HOME variable ?
It should be 1.7 or later. run echo %JAVA_HOME%
Also check for the JDBC driver version.
Platform Support Guide for more information.
https://collaborate.pega.com/discussion/prpc-5x-6x-platform-support-guide-easy-find
