Select All is not selecting only the Filtered records
Hi Team,
this is regarding the article
https://pdn.pega.com/support-articles/select-all-not-selecting-only-filtered-records
Node ID: 1130646
SA ID: SA-24006
As per the fix, there is a hotfix(HFix-27272) for the same in 7.1.7. I like to know whether this is taken care already in the higher versions 7.2.x. We are currently using 7.2.1 and still the feature does not work as intended.
we have so many usecases that is required of this feature.
Please do the needful at the earliest.
Regards
bharath
