accenture
Pega AUT Test ID generation
Pega AUT feature which creates test ID for UI elements. We are trying to automate UI testing part.
In a section for each field we have a generated testID, when we click on properties panel of any field we have identifiers section in which test ID will be present.
In couple of scenarios testID field is not visible in identifiers section(based on visibility condition). for such fields these test IDs are not available in web element attributes of section(test-Data-id) for such fields facing issue getting test ids.
Can anyone explain the reason behind this visibility condition?-
***Updated by moderator: Lochan to add Category***
