Issue with Data Page PRPC 7.1.9
I am able to run a particular data page (other data pages are running fine) only with tracer on. If I try to run this data page without the tracer I am not getting any results. Could this be a possible PRPC issue?
Did you miss our WEBINAR: Transform IT & Operations with AI: Pega Blueprint Advantage? Watch the REPLAY!
This webinar will show how AI is revolutionizing these functions and how Pega’s Blueprint Solution can help you fully leverage AI to meet your goals.
Pega Cloud status shows the overall health of Pega Cloud products and services, by region.
Manage your subscriptions by clicking the Subscribe To Updates button. Check out our Support document for more information: Pega Cloud Status
Hello Tarun,
Thanks for posting your query in PSC. :)
From the issue description, I understand that the particular data page is a custom page. Functionality of data page's execution does not depend on tracer. Could you share screenshots of the data page and actual behavior with and without using tracer?
Rincy
Hi Tarun,
I feel that right page context is not getting passed while fetching the results to the data page. And it is working fine, when the tracer is on. Can you please check whether all page details are mentioned correctly or not. If you are unable to find the root cause, then please create a SR for this issue.
Prudhvi
Hello Tarun,
Good Morning!!
Apologies for delay in response.
From the provided screenshots, I think that data page is not correctly configured(since I cannot see all the tabs of the data page) and need to investigate on the tracer(when enabled). pxObjClass with tracer enabled is Code-Pega-List and without tracer enabled is Embed-ExpectedResults. Could you raise a Support request for this.
Rincy
Hi Tarun,
Please create an SR under my support to quickly addressing of your issue. Or, give complete tracer file and screenshots of all tabs of DataPage, datatransforms as well.
Prudhvi
Hi Tarun,
Please let us know the SR number here once you create it. We will tag it to your post above and track it to closure!
Lochan | Community Moderator | Pegasystems Inc.
