Deloitte
DE
Last activity: 24 Oct 2016 0:54 EDT
Filtering data in report definition - Enable Adding/removing column
I have the same problem. Im using report definition and unable to display add column removed column like it does in the list view. i have follow the same indication unchecking edit report from the Enable toolbar. Please let me know if Pega has a fix for this or if i need to open an SR. Different forum has the same Title however it's from 2015. Not current users looking at the old post. Opening a new Forum.
Thank you,
As per my understanding you are trying to looking for below options in the Report Definition,
We can achieve this requirement different with report definition, by tweaking the report definition's configuration using "Report Editor".
Steps:-
Make sure you have checked/enabled "Enable right-click column command" under "Report Viewer" tab of report definition.
1. Click on "Edit Report".
2a. Right click on header of the column, a pop-up will appear with “Delete” and other options for report definition.
2b. To add a new column in report definition, drag and drop columns from left panel in to the work area.
3. Click on “Apply Charges & Exit” on top right corner to see the changes. Below is the screen-print for reference.
I have also attached the above images, if it isnt clear to view here.
Please notify me, if it helps you.
Asif
