Endsleigh
Last activity: 3 Oct 2016 12:44 EDT
Time Comparison
Can anyone help with how I would go about comparing a time to a set time in order to stop an automation from running i.e. if the last successful run through the automation was at 20:11 and this is after 20:00 the automation does not run again.
I presume you would start with extracting the current date/time using DateTimeUtil (Now) but have no idea where to go from here.
***Updated by Moderator: Lochan. Removed user added #helpme tag. Apologies for confusion, shouldn't have been an end-user option***
You can use the DateTimeUtils for that as well. Today will give you a DateTime value that is midnight, then you can Add to it. Here is an example.
