Unusual large DB table SYS_LOB0000063510C00085$$
Hi Team,
We are trying to understand why SYS_LOB0000063510C00085$$ is significantly huge?Is there any remediation to fix the size of this table? We are in the process of migration from 5.5 to 7.2 and would like to see if there is an opportunity to that this table can be skipped while exporting or could be reduced in size?
NBB_WORK is our work table. The SYS_LOB0000063510C00085$$ table corresponding to it(last row below) is of very large size.
OWNER SEGMENT_NAME SEGMENT_TYPE S.BYTES/1024/1024 TABLE_NAME COLUMN_NAME
Hi Team,
OSB_RULES_PRD SYS_LOB0000063650C00049$$ LOBSEGMENT 115.1875 PC_ASSIGN_WORKLIST PZPVSTREAM
OSB_RULES_PRD SYS_LOB0000063890C00085$$ LOBSEGMENT 160 NBB_BRN_WORK PZPVSTREAM
OSB_RULES_PRD SYS_LOB0000063728C00053$$ LOBSEGMENT 379.1875 PR4_RULE_PROPERTY PZPVSTREAM
OSB_RULES_PRD SYS_LOB0000063734C00039$$ LOBSEGMENT 396.1875 PR4_RULE_FILE PZPVSTREAM
OSB_RULES_PRD SYS_LOB0000063725C00051$$ LOBSEGMENT 904.125 PR4_RULE_FLOW PZPVSTREAM
OSB_RULES_PRD SYS_LOB0000063722C00123$$ LOBSEGMENT 1984.125 PR4_RULE PZPVSTREAM
OSB_RULES_PRD SYS_LOB0000087496C00085$$ LOBSEGMENT 2884.1875 NBB_RMT_WORK PZPVSTREAM
OSB_RULES_PRD SYS_LOB0000063510C00085$$ LOBSEGMENT 521128.125 NBB_WORK PZPVSTREAM
