Datacom Systems Pvt. Ltd.
Last activity: 27 Sep 2016 21:26 EDT
Lack of privilege issue to open RULE-OBJ-ACTVIITY
I have created a source activity for a data page which will be get the requried results for the data page.when moved the same rule category to higher version, the activity is not opening an giving an error like Lack of privilege issue to open RULE-OBJ-ACTVIITY to the logged in operator ID.
The same activity when tried opening with pega admin oeprator ID ,was able to open it. The application specific operator ID was not able to open it.
Steps done to resolve the issue:
1. Revalidate and save rule performed.( did not work)
2. Deleting the cache to check whether the rule can be opened( did not work).
3. Checked the privileges of the operator ID it is the same as the PEGA admin ID.
Kindly let me know whether anything further can be done, to make the rule available.
thanks in advance.
