JP
OpenSpan 7.1 How to open password protected Excel workbook
Is it possible to open a password protected Excel workbook using MicorsoftExcel Connector ?
If it is possible how can I do it?
Chunzhi
Hi Chunzhi,
Here is how you would do open a password protected worksheet. It is important to note that Excel must be running first for this to work. If you load an empty spreadsheet to start with that will do the trick like this.
Then open your sheet - obviously this has some hard coded values which you may choose to input using variables. Create the _ApplicationProxy1 and the workbooksProxy1 by extracting a proxy from ExcelApplication and Workbooks.
The script to provide the Missing value object is:
Chunzhi,
The excel connector does not have a build in function or method that allows you to unlock an excel workbook. However, I would suggest creating a script to do so. You should be able to pass the workbook/worksheet into the script through automation and use the following method call to unprotect the worksheet:
sheet1.unprotect(Password);
The following link describes how to iterate through a list of worksheets through automation. What's really useful about this link is that it also shows what references should be needed to work with Excel through script.
http://help.openspan.com/71/Components/How_to_Use_the_Script_Component.htm
Hi Chunzhi,
Accenture
Hi Jeff,
I was able to open a password protected excel using above reference, but how to use "GetCellValue" from a WorkbooksProxy? When I use MicrosoftExcel1-GetCellValue, its picking up from Empty.xlsx and not from PasswordTest.xslx file...
Arun
CAPGEMINI
Hi arun,
You found answer for above question,if found please share the answer
ServiceNow
JP
Since I need this information too, have created the following thread:
https://collaborate.pega.com/question/how-setget-cell-values-password-protected-excel-workbook
RBC Royal Bank
Hi Jeff, the script is an older version of Pega. Are you able to provide a more recent script/way of opening a protected workbook?
Accenture
how do we use text to column property in excel connector.
Hello!
I believe you have asked this question as a new post: Excel Component - Text to Columns Property
Please continue the discussion in the new post.
Thank you,
