Cts
Last activity: 1 Sep 2016 8:43 EDT
Pega Rule Indexing issue
We have recently upgraded our application from Pega 5.5 to Pega 7.1.9.
And we tried using the Elastic search from then on.
When we tried running the Rule - Indexing . The Rule indexing is completed successfully after an Hour.
But when i see the Log files there are around 1880 rules couldn’t be indexed as they raised an error like the following:
2016-08-17 11:34:09,826 [fault (self-tuning)'] [ STANDARD] [ ] [IOPSSandbox:04.19.01] ( internal.es.AbstractIndexer) WARN F115082 - Failed to index instance with key [RULE-OBJ-WHEN CSG-FW-IOPSFW-WORK-COWO0771 ISVALIDPID #20160222T161942.839 GMT]
- com.pega.pegarules.pub.PRRuntimeException: The number of database bytes input for this interaction has exceeded the ERROR level for Requestor B7E6A9E4DE13CCF40EE4D6212EE1AB54F, operator Maximum bytes: 250000000 Actual bytes: 250002827: code: <none> SQLState: <none> Message: <none>
In this case, it’s not possible to find named rule, it will only be possible to find it by using ‘old:’ syntax.
Does any one face this issue with there applications?
Any Article or Document would be helpful.
Bharath.
- 6 Views
***Updated by Moderator: Marissa. Removed user added Ask the Expert group tag. Apologies for confusion, shouldn't have been an end-user option; updated category.***
