Achmea
Last activity: 22 Aug 2016 9:24 EDT
AES Error - Error in RDB-Delete PegaAES_Data_Guardrail.Action
Can anyone help me with this error in our AES logging?
I suppose somewhere a dateformat is set wrong, but where to correct it?
2016-08-10 07:00:02,091 [ WebContainer : 12] [ STANDARD] [ ] [ AES:07.13] (.PegaAES_Data_Guardrail.Action) ERROR xxxxxxx.unix.corp|xxx.xx.xx.xx|SOAP|PegaAES|Events|logAlert|AACECB7FAE71FFD1021D4F2508D1DCF00 - Error in RDB-Delete
com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: -180 SQLState: 22007 Message: The syntax of the string representation of a datetime value is incorrect.. SQLCODE=-180, SQLSTATE=22007, DRIVER=4.14.113
SQL: delete from PEGA_DATA.pegaam_guardrail where pxCreateDateTime = ?
SQL Inserts: <10-Aug-2016>
***Updated by Moderator: Marissa to remove the Ask the Expert group tag. Apologies this should not have been an end-user option***
Pegasystems
This error happens when the format of the date time value being set (in this query case for pxCreateDateTime) is invalid. Is it possible to share the complete stack trace? Also, is this a custom query?
Updated: 11 Aug 2016 12:27 EDT
Achmea
Rajiv,
This is a query out of the Pega Box, complete stack trace underneath.
Kind regards,
Arjan
Rajiv,
Kind regards,
Arjan
2016-08-11 07:00:02,774 [ WebContainer : 33] [ STANDARD] [ ] [ AES:07.13] (l.access.ConnectionManagerImpl) ERROR usa10217.unix.corp|XXX.XXX.XX.XX|SOAP|PegaAES|Events|logAlert|A3648DC7FF9A725F5F46D91DDD9AEAC84 - Not returning connection 11 for database "pegadata" to the pool as it previously encountered the following error
User ID: (unknown)
Last SQL: delete from PEGA_DATA.pegaam_guardrail where pxCreateDateTime = ?
com.ibm.db2.jcc.am.SqlDataException: The syntax of the string representation of a datetime value is incorrect.. SQLCODE=-180, SQLSTATE=22007, DRIVER=4.14.113
at com.ibm.db2.jcc.am.ed.a(ed.java:669)
at com.ibm.db2.jcc.am.ed.a(ed.java:60)
at com.ibm.db2.jcc.am.ed.a(ed.java:127)
at com.ibm.db2.jcc.am.oo.b(oo.java:2366)
at com.ibm.db2.jcc.am.oo.c(oo.java:2349)
at com.ibm.db2.jcc.t4.ab.l(ab.java:370)
at com.ibm.db2.jcc.t4.ab.a(ab.java:62)
at com.ibm.db2.jcc.t4.p.a(p.java:50)
at com.ibm.db2.jcc.t4.rb.b(rb.java:220)
at com.ibm.db2.jcc.am.po.qc(po.java:3497)
at com.ibm.db2.jcc.am.po.b(po.java:4458)
at com.ibm.db2.jcc.am.po.kc(po.java:2820)
at com.ibm.db2.jcc.am.po.execute(po.java:2799)
at com.ibm.ws.rsadapter.jdbc.WSJdbcPreparedStatement.pmiExecute(WSJdbcPreparedStatement.java:958)
at com.ibm.ws.rsadapter.jdbc.WSJdbcPreparedStatement.execute(WSJdbcPreparedStatement.java:625)
at com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl.execute(DatabasePreparedStatementImpl.java:581)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6139)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6613)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6569)
at com.pega.pegarules.data.internal.access.DatabaseImpl.deleteRDB(DatabaseImpl.java:5849)
at com.pegarules.generated.activity.ra_action_parseguardraildata_d3214a783cf31dd8dbeda2e06217b7da.step4_circum0(ra_action_parseguardraildata_d3214a783cf31dd8dbeda2e06217b7da.java:576)
at com.pegarules.generated.activity.ra_action_parseguardraildata_d3214a783cf31dd8dbeda2e06217b7da.perform(ra_action_parseguardraildata_d3214a783cf31dd8dbeda2e06217b7da.java:129)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10521)
at com.pegarules.generated.activity.ra_action_parsealertline_7043315bc4df33f3bf0cd7cd2ba5821e.step6_circum0(ra_action_parsealertline_7043315bc4df33f3bf0cd7cd2ba5821e.java:1382)
at com.pegarules.generated.activity.ra_action_parsealertline_7043315bc4df33f3bf0cd7cd2ba5821e.perform(ra_action_parsealertline_7043315bc4df33f3bf0cd7cd2ba5821e.java:154)
at com.pegarules.generated.activity.ra_action_parsealertlinesoap_7a26e04c4a9359d23c155291fc34db0b.step4_circum0(ra_action_parsealertlinesoap_7a26e04c4a9359d23c155291fc34db0b.java:313)
at com.pegarules.generated.activity.ra_action_parsealertlinesoap_7a26e04c4a9359d23c155291fc34db0b.perform(ra_action_parsealertlinesoap_7a26e04c4a9359d23c155291fc34db0b.java:103)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:461)
at com.pega.pegarules.integration.engine.internal.services.ServiceAPI.runActivities(ServiceAPI.java:1881)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:385)
at sun.reflect.GeneratedMethodAccessor93.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.integration.engine.internal.services.soap.SOAPService.invoke(SOAPService.java:579)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
at sun.reflect.GeneratedMethodAccessor83.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374)
at sun.reflect.GeneratedMethodAccessor91.invoke(Unknown Source)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:595)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at com.ibm.ws.cache.servlet.ServletWrapper.serviceProxied(ServletWrapper.java:307)
at com.ibm.ws.cache.servlet.CacheHook.handleFragment(CacheHook.java:562)
at com.ibm.ws.cache.servlet.CacheHook.handleServlet(CacheHook.java:255)
at com.ibm.ws.cache.servlet.ServletWrapper.service(ServletWrapper.java:259)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1230)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:779)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:478)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1114)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:919)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1662)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88)
at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCompletedCallback.complete(SSLReadServiceContext.java:1818)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1881)
2016-08-11 07:00:02,780 [ WebContainer : 39] [ STANDARD] [ ] [ AES:07.13] (l.access.ConnectionManagerImpl) ERROR usa10217.unix.corp|XXX.XXX.XX.XX|SOAP|PegaAES|Events|logAlert|A66D9E770C07DE2472DFF6558D61AFDB6 - Not returning connection 7 for database "pegadata" to the pool as it previously encountered the following error
User ID: (unknown)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:816)
2016-08-11 07:00:02,781 [ WebContainer : 39] [ STANDARD] [ ] [ AES:07.13] (.PegaAES_Data_Guardrail.Action) ERROR usa10217.unix.corp|XXX.XX.XX.XX|SOAP|PegaAES|Events|logAlert|A66D9E770C07DE2472DFF6558D61AFDB6 - Error in RDB-Delete
SQL Inserts: <11-Aug-2016>
Caused by SQL Problems.
Problem #1, SQLState 22007, Error code -180: com.ibm.db2.jcc.am.SqlDataException: The syntax of the string representation of a datetime value is incorrect.. SQLCODE=-180, SQLSTATE=22007, DRIVER=4.14.113
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:6220)
Caused by:
... 78 more
2016-08-11 07:00:02,784 [ WebContainer : 33] [ STANDARD] [ ] [ AES:07.13] (.PegaAES_Data_Guardrail.Action) ERROR usa10217.unix.corp|XXX.XX.XX.XX|SOAP|PegaAES|Events|logAlert|A3648DC7FF9A725F5F46D91DDD9AEAC84 - Error in RDB-Delete
Caused by:
... 78 more
Pegasystems
Which version of AES and Pega platform is this?
Achmea
PEGA 7.1.8
AES 07.13
Might it be possible we have our AESRemoteuser running with the wrong locale?
I discovered that te locale within this user was empty
Pegasystems
Possibly. Do you know in which locale your node is running in?
Also, pxCreateDateTime contains both date and time (TIMESTAMP column) but the SQL insert value only shows a Date and not date and time. That might also be the reason for this error.
Achmea
How to find in which locale my node is running in.
Pegasystems
There are a set of system properties that might help. You can try checking these
http://www.oracle.com/technetwork/articles/javase/locale-140624.html#using
