How to override the pyInvokeRestConnector activity to change SSL Protocol version in PRPC v7.1.7
How to override the pyInvokeRestConnector activity to change SSL Protocol version in PRPC v7.1.7?
Thank you Abhijit and Vidyaranjan,
This issue or question has been addressed as below -
- Save the “pyInvokeRESTConnector” rule under Pega-IntergrationEngine:07-10-15 ruleset to your own application ruleset.
- Modify the Step4 (Initialize HTTP Client and handle authentication) Java code as below to modify the protocol version from “SSL” to “TLSv1.2” as highlighted below –
if (serviceURL.toLowerCase().startsWith("https"))
com.pega.apache.http.conn.ssl.SSLSocketFactory sf = null;
// HFix-9721 START
String truststoreName = stepPage.getString("pyTruststoreName");
String keystoreName = stepPage.getString("pyKeystoreName");
// Create a new SSLContext that merges custom PRPC keystore/truststore with default JDK ones
javax.net.ssl.SSLContext sslContext = tools.getServiceUtils().getSSLContext(keystoreName, truststoreName, protocol);
sf = new com.pega.apache.http.conn.ssl.SSLSocketFactory(sslContext);
- Save the rule and test your Connect-REST.
Telstra
Hi Ankur,
I wouldn't suggest overrding invoke activities [You may lose future updates coming to this activity]. Please raise an SR with Pega to check your options.
If that's a parameter, you can set it to a value you want before calling "Connect-REST" method.
Hi Ankur Das,
As the next plan of action, if you go ahead and raise an SR with GCS , I request you to share the SR number here, so that we can track it for you within the thread.
Vidyaranjan A V | Community Moderator | Pegasystems Inc.
// HFix-9721 START
As you say,
modify the pyInvokeRESTConnector activity to not use "SSL" I use the following snippet:
String protocol = myStepPage.getString("pySSLProtocolVersion");
if(protocol==null) {
protocol = "SSL";
This requires specialising Rule-Connect-REST.RuleFormLayout to include section Rule-Connect-.pzSSLConfiguration, it however gives you the ability to define the protocol on a connector by connector basis.
Schwab
How to fix this for 7.1.6 PEGA version?
if we try to use above code, its giving error as below:
The method getSSLContext(String, String, String) is undefined for the type ServiceUtils
any quick workaround for this?
Any update on this query?
