Override Properties
HI,
Can We override selected properties in a data page record, withe out modifying the other properties in that particular record
Thanks.
HI,
Thanks.
Thanks Gowrishankar,
I tried your suggestion.values are changing in my selected properties, but the rest of the properties are becoming blank. I want them to be the same without becoming blank.
any way thanks for the suggestion brother, i will keep on trying.
Regards.
Sasitha.
I have tried the scenario from my end, I did not get the rest of the properties blank. Could you please share the structure and source of your data page?. Also please share the details on how you are editing the selected properties values?.
Gowrishankar.
Hi Gowrishankar,
Hi Gowrishankar,
This is the Activity that Save Change Change Patient Details
Is their a better way( ex- activity method that Can lock a Data page Record Change record Details and override Same record without Changing other property values).
Regards.
Sasitha.
Hi Ssitha,
If you would to like to override the values against the certain properties in a data page record, you can do that, if the edit mode of data page configured as editable as shown in the below screen shot.
Please let me know if this helps.
Gowrishankar.
